hello, i use N91 n since sum days themes installed do not appear in application manager(not a single),so i cant delete(uninstall) them.
But I managed to uninstall those themes by deleting them from the hard disk using my phone as "Mass Storage" device, but the themes remain on the log in App.Manager and if you try to reinstall them you get the message "unable to install file".
I was wondering is there a way to clear the log so that the theme can be reinstalled or any other solution.. wat do u think is the problem???
my application manager was working properly before n then suddenly it started giving this problem.
plzzzz help!!! :con?
