Hi im after some messenger software for my new nokia 5800,the phone isnt listed on the ebuddy site and fring gives me a certificate error when trying to install,also windows live wouldnt connect once installed,anyone had any luck?
thanks
thanks
Found one when I was browsing. Haven't personally tested it.
http://my.s60blog.com/viewtopic.php?p=1499#p1499
Update: Found another -> http://www.shapeservices.com/en/index.php?deviceid=1416
google for slick
fring has released a new version for 5800
ebuddy also works
Use Fring it's the most user friendly among others
they already have the full version for nokia 5800
i get a certficate error when trying to install or load fring! 😞
strobez1977 wrote:i get a certficate error when trying to install or load fring! 😞
I have successfull installed fring 😊 msn does work on this app
having great fun with my wifi connection
:icon14: first post
im using the new version of fring and i also use slick 😊
granadas wrote:im using the new version of fring and i also use slick 😊
you can also refer here for messengers for s60. or 5800. myghimh.blogspot.com
