Got an stupid idea and woundering if it will work
4 replies · 2,579 views · Started 08 March 2009
I used the navi wheel on my N85 for about 2 weeks, and i found out that the whole black part in side the silver rectangle is sensitive. So i was woundering if someone could create a hack or plug in to use the black part of the navi wheel as optical joystick in the web browser like the ones samsung phones have.
sorry, forgot to reply to this..
O2 are running a forum program for developers and customers to their network which looks at applications for all handsets. You would need to be UK based tho... which Im assuming you aren't.
Info if you wanted it is at www.o2litmus.co.uk. You can submit ideas, test unreleased apps etc from it, although at this point it is in its infancy.
