OK, I am stupid, but Bluetooth with my Tohsiba doesn't work
1 replies · 1,292 views · Started 26 February 2003
I really tried everything. Paired the two. And my Toshiba satellite pro built in bluetooth manager sees ( sometimes) the 7650. when searching it finds it but mostly it says: not connected. What am I doing wrong?
I see the devive in my service centre, I paired them I made the 7650 trusted, I see the toshiba compuer on my 7650, but on everythinbg else it says: not conencted; pls help.
Huib van den Oever
what your supposed to do is set the 7650's phone visibility to "Shown to All", then on the Toshiba BT Stack, choose Bluetooth > Device Discovery and it should search for any Bluetooth devices, and find the 7650. And also set the Toshiba BT Stack to Disoverable and what not just so that the 7650 can find it if it needs to.
Then from the drop-down list, go to Remote Devices, and the 7650 should be listed, select Bluetooth Serial Port and click Connect and it should work right (assuming BT is enabled on both the computer and the phone of course).
