Okey, there are some threads about this already, i know..
What the difference here is that in the other threads there is some conclusion about UK phones.
From the begining:
I upgraded to 20.0.012, then experiensed some troubles so I did a soft reset of the phone that solved my problem...
However I cannot install ANY application 😞
This is not a UK-phone, that seems to be the consensus in other threads, that this problem only affects theese phones...
So, I have a 5800XM, with 20.0.012 firmware version and product code 0577196(Im in Sweden).
Clock is set to Local time, and correct time and date..
Any ideas?
Maybe a reinstall of the same firmware version? Can't try right now tho, no access to physical windows-computer, only a virtualized one, didnt go so well 😊
