I have just realised that i have a broken bit on the top of my phone but i dont know which part i need to order to replace it and where to get it from. I didnt want to take it apart to find out incase it got worse. I have attached some photos so hopefully some one can point me in the right direction.
Thanks All😊
It looks like the part you need is the back housing. Unless it's attached differently than the original N95 it is very easy to replace. Be careful on ebay as non genuine housing parts scratch and wear quickly in my experience. If you don't mind and want a cheap aftermarket one dealextreme.com has them for €3.
Hi mate i took the back housing off today and its not that? Thats why im asking on here if some one else has changed this bit so i know what to look for?
Thanks anyway tho
As i can see,you must change the slider and the back housing aswell.Hope this can help you.
You need the part on the left in the above photo. Obviously the black 8GB variant though.
Ok cool thanks for that mate know where i can get one from other than ebay?
You might want to update your profile to include that info.😊
Try these places, but failing that, there's always ebay...
www.accessorylink.co.uk
www.mobilefun.co.uk
www.blueunplugged.com
yeah, blueunplugged have always been good for me... ordered a fair few parts and quick shipping... they even have the prism stuff which Ive always found hard to get.
Right found one on ebay can someone just confirm this is the correct part?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=260354484754
Also how easy a job is this? Do i need to do any soldering or is just a take apart and replace the broken bit job?
Thats the one. I have purchased from thay seller too in th past, so you should be fine.
No soldering needed, just plug and play 😊
Micky! wrote:Thats the one. I have purchased from thay seller too in th past, so you should be fine.No soldering needed, just plug and play 😊
Ah cool i will get it ordered.
So its a pretty simple job then mate?
