Podcasting App: Problem connecting via WLAN connection
2 replies · 5,399 views · Started 16 March 2009
I'm having a problem with the podcasting application when trying to connect through my WLAN. When attempting to connect to the sites listed under "Directory" I get the following error message:
"The Service is not available for this terminal"
However, I can browse the internet just fine with the same WLAN connection. Any idea what the problem could be?
Tzer2 wrote:Which of the directories are you using? Or do you get the same error message with all of them?
Yes, all of them
You might want to try altering the connection type from the Podcasting app's settings section, see our tutorial for more details:
http://www.allaboutsymbian.com/features/item/How_to_download_and_subscribe_to_podcasts_on_the_Nokia_5800_and_you_dont_even_need_a_computer.php
Tried all connection types, but same problem. The only thing I can think of is that I've changed the product code of my mobile, but have yet to update the firmware to that region since I already have latest firmware (from a different region). Could that be the problem?
