recover contacts
3 replies · 5,135 views · Started 18 March 2009
:con?:con?😮:frown::frown:[FONT="Arial Black"]i recently got my n 95 8 gb formatted���.i had backed up the contacts �.my pc showed some 489 contacted backed up but after fomating my phone i could find only 22 contacts backed up ��.i dont know what to do ���someone pls help me�..i would be really nice of anyone who helps me����.i need all my contacts[/FONT]:con?:con?:con?
badshah wrote::con?:con?😮:frown::frown:[FONT="Arial Black"]i recently got my n 95 8 gb formatted���.i had backed up the contacts �.my pc showed some 489 contacted backed up but after fomating my phone i could find only 22 contacts backed up ��.i dont know what to do ���someone pls help me�..i would be really nice of anyone who helps me����.i need all my contacts[/FONT]:con?:con?:con?
keep trying to restore the back up, i normally back up contacs using nokia backup and also in the contact app u can export . i also have a back up on O2 bluebook.
when you are restoring, only restore contacts
if it works do the export thing and do full restore if u need to and if u have contact problem then restore using the import in the contact app.
good luck
First of all its a workaround or a suggestion to you available from some third party applications
Since your issue is with Contacts, you can search in google for an application called Nokia_Contact_Transfer.exe or you can download an application called noki to view the contents of your backup .nbu file. If your .nbu backup file has backuped all the contacts and if its not broken, you can use either of the above application to get your contacts.
As previous post to mine mentioned, you can also try to restore Contacts alone using Nokia's Content copier. Are you using Nokia PC Suite's Content copier or OVI Suite's Content Copier ????
And this isn't very helpful after the fact but sync your contacts to something external. Like zyb.com or ovi. No reliance on your phone or your backup then...
Good luck!
D
