IR-World clock pro problem
1 replies · 1,842 views · Started 27 February 2003
I noticed something strange, When I connect my N7650 via infrared to my PC, and after disconnecting if I open( it is closed it is not in background) World clock Pro, the clock of the phone totaly mixed up. It shows totaly wrong time.
Did some one expirienced such problem?
V4.39, World clock pro-121 registered.
BR, Miro
I connect a lot via IR, have World CockPro on v3.16: only sometimes I notice the main clock is showing the "destination" or secondary time. I had thought that this happened when I entered the app, without changing any options.
I'll check and see if an "IR events" modify the settings.
Ps if you are synching with PC suite, your phone will use the time as on your PC
Paul
