Anyone Tried Jabra FreeSpeak Bluetooth Headset?
5 replies · 1,795 views · Started 27 February 2003
has anybody tried this handsfree with there n7650? i realy like the idea, but i wont to know if it realy works and if so how good or bad it is. and one more qestion-which adaptor is siutibal for nokia 7650 ( is 2.5mm Adapter or is there alternative disain for nokia)
there are a lot of doubts re bluetooth audio (see the rest of the forum)
I don't know if this is practical, but can you find a local distributor and try it in his shop
Same question goes to anyone near a BT retailer 😃
Paul
I contacted Jabra and they gave the same reply as Plantronics.
Yes the headset with rhe 2.5 mm adaptor works with the 7650.
No, it can't be exported to outside North America
That one on expansys doesn't seem to be the one with the headset jack plug, just a normal bluetooth headset.
You are right Lakywhite
Expansys only sells headset without adaptor. It won't work with 7650.
See link to forum that might be able to get Jabra in UK
http://my-symbian.com/forum/viewtopic.php?t=2892
I hope it's ok to post this link?
