Mail for Exchange 2.9 is out
3 replies · 10,746 views · Started 20 March 2009
New version of Mail for Exchange out - 2.9
Get it from the Nokia for Business Site
http://www.businesssoftware.nokia.com/mail_for_exchange_downloads.php
Select E71 (they havent updated it for the other phones - but works even on N95).
NEW FEATURES IN THIS RELEASE
�Access Point Groups/Destinations
Mail for Exchange can now actively switch between WiFi and GPRS connections automatically if your phone supports Destinations. This feature is only available on S60 3rd Edition, Feature Pack 2 and S60 5th Edition phones.
To identify your device, visit:
http://www.forum.nokia.com/devices/matrix_s60_1.html
See your phone User Guide for details about Destinations.
�Calendar, Contacts, Tasks, are disabled by default on new installs. This is to prevent users from inadvertently losing Calendar, Contacts and Task data.
�When editing your Out of Office (OoO) message on the the device, Mail for Exchange retrieves the current OoO message from the server when the setting/tab is accessed and OoO is set to �Yes�, instead of periodically as in previous versions. This may cause a short delay and requires connectivity with the server.
�Much better battery life in adverse network conditions. If the Mail for Exchange client can�t maintain a connection to the Exchange Server, it automatically switches to polling every 15 minutes. The client will switch back to Always on at the next scheduled period.
�Mail for Exchange setting tabs are no longer dynamically displayed, instead all tabs are always displayed.
�Manage your device by name instead of IMEI via Outlook Web Access (OWA) email client (if account allows). Users of OWA can perform device management features on their phone clients such as wiping the device. The phone model name is now visible in the status field. This is helpful for users who are synchronizing several phones.
�Pictures in contacts are now synchronized.
ERROR CORRECTIONS
�Meeting with several attendees: Meetings in the calendar with a large number of attendees (>1000) will now synchronize successfully. Only the first 20 meeting participants will be shown in the meeting.
�Reply/forward to a completely fetched email: When you try to reply to or forward a large email (180K < message body < 200K) that has been fully downloaded there are no longer any issues.
�Deleting access point used by Mail for Exchange: Mail for Exchange now gives an error when a Company Directory (GAL) search is performed and the access point used by Mail for Exchange has been deleted from the device.
�Company directory crashes: Several company directory crashes have been fixed.
�Synchronization issues with Exchange 2007 servers: Some events were causing the calendar synchronization to stop working. These have been corrected.
�Missing calendar events with Exchange 2007 servers: Updates to calendar events are now handled correctly.
�Mail for Exchange doesn�t sync when Encryption is turned on for E66 and E71: Mail for Exchange and device software updates now allow for Mail for Exchange to synchronize when encryption is turned on.
�Guatemalan Daylight Savings Time calendar events were �off� by 1 hour: Calendar events in Guatemalan Daylight Savings time are now correct. The change may also affect other time zones.
�Memory Full: Mail for Exchange now properly stops synchronizing when memory is full and restarts when memory is freed.
This would be great on my E75 as I want the Access Groups/Destinations function. Has anyone successfully installed it on an E75?
