Problem with 6220 Classic
2 replies · 7,862 views · Started 21 March 2009
Hi!
Unfortunately I failed to upgrade the software to my Nokia 6220 Classic because I had plugged in the USB cable into the front of my computer. Nokia Software Updater then said that you should not plug the cable in to any kind of USB adapters and so on - AFTER downloading and starting to format my phone.
Now it wont start. When holding down the "on" button it just vibrate a little and the screen lights up a little bit, then it goes back to completely black again. I have tried to hold down "green button" + "3" + "*" and turn the phone on, but it does not seem to begin formatting. I have tried it at least tree times. Does anyone know for how long I should hold down the combination? Or how I should do otherwise? 😮
I'd be very happy if someone could help me with this!
Peace out
Hi oskan,
Why dont you try to run firmware update again and check 😊 Your issue will be resolved if you redo firmware update. Make sure that your phone is fully charged and it is in general mode 😊
