dust
4 replies · 1,895 views · Started 27 February 2003
Just purchased a 7650. Great phone, but you knew that already. Have noticed dust collecting under the glass on display tho..not lots, but enough to be noticeable. Has anyone had this problem? Thanks in advance.
If you do a search of the forum you will find several threads discussing this.
You m ay have to remove the cover to remove it.
Bob 😊
HI!...
yeah!.. just yesterday i notice the same...
one little damn grain dust.. between the display and the plastic glass cover ... :evil:
any link to the topic about dust?
thanks!
cya! 😃
Try
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=8087&highlight=dust
or
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=5741&highlight=dust
Or just search for the work Dust in the 7650 forum, lots more links
Bob 😃
