How to change it?
Thanks in advance!
Operator Logo?
😊 As far as I know the only way to change Operator Logo is changing to another Operator . Or maybe hacking ..... Not my advice !
😊 Regards jApi NL
Thanks for the input! 😃
There is a tool to remove it i.ew. make it blank. I had it on my N80 some time ago.
Mmm, try this
Gonna try it!
Thanks a lot my friend 😃
😊 Interesting . Does it work ? And how does it work ? On the Nologo Forum and the Documentation there is no further information .
😊 Regards jApi NL
here's how to make custom operator logos in os9.1, os9.2 and 9.3 and 9.4.
have a hacked phone and unhindered access to the Private folder.
in there is a folder called 10000850, this is where your logos go.
it is feasible to set one up for every network, i have 5, one for each major uk network.
before you throw your images in, you need to:
A: cmake your image in BMP format and then use BMConv.exe to convert to MBM (or another mbm converter if you prefer).
B: get your network code. that's your MCC and MNC
C: name your logo.
Logo_234_33_OTA.mbm
the above is my orange UK logo, MCC 234 is uk, MNC 33 is orange. Google these codes. AAS won't allow me to link to the list i found cos i'm a n00b.
now drop that into your C:\private\10000850 folder and restart your phone (some require a restart (n95) some do not (5800XM)).
This is as much as i will help you, since all i was looking for when i found your discussion was the correct logo dimensions for a 5800 Xpress Music.
Good luck!
