E71 Charger
3 replies · 3,468 views · Started 24 March 2009
Does anyone know whether I can use a N80 charger for my E71? The charger is a AC-4X. Any known issues ?
If it fits, it should work; Nokia has only two chargers (thin -newer- and wide -older- pins).
RickyS wrote:If it fits, it should work; Nokia has only two chargers (thin -newer- and wide -older- pins).
If your extremely paranoid and want to ensure the charger won't destroy your phone before you attempt to use a different charger, make sure both chargers output identical voltages, and have the same current ratings.
All the info is within the fine print on the AC chargers.
