Do you know how to uninstall HANTRO CP video ? It's not possible in the software management because it is not present (I don't know why...)
Thank's
Thank's
I've tested (and uninstalled) both the 2.1 and 3.3 versions and both remove themselves cleanly by the usual "Remove" option in the manager.
Not sure whats happened for you !
Carpathian
NB. Before I'm flamed/removed/banned for daring to mention that I'm a UK user trying these items I'd just like to point out that they were looked at for a test and that there is NO commercial video software to choose otherwise for the 7650 - when there is, and it's usable, I'll be buying some !
I don't know why my Hantro CP is not in this manager ....
Have you tried installing again then removing from the manager.
I had an application do the same and managed to remove it by reinstalling it first.
Good Luck
Bob 8)
I think you cannot find the application in the manager because probably you installed it via wap download.
Try with with SeleQ.
If you wanna install it via infrared, e-mail, bluetooth and you will have it in the manager
BR,
Miro
However you install an application it will appear in the manager.
You may not have the installation file if you install through WAP, but you will have the application.
The manager shows a list of registered software, if applications do not remove themselves correctly you may get icons in the menu without application listed in the manager or apps in manager without icons in the menu, but you should always get an entry for an application. If you did not, how would you remove it?
Bob 😃
what's the last version of hantro?
[quote="slack"]what's the last version of hantro?[/quote]
Version 3.3 is the latest. In the "About" dialog it calls itself Video MMS (c) Hantro Products now.
