SIP over Nokia N95
0 replies · 4,727 views · Started 28 March 2009
Hi Symbianers,
I would like to know if anyone here has experience sip expiration problem to a sip server (asterisk). I can successfully register to a sip server using the stack SIP Application of N95 over wifi but the problem is after 2 mins the phone can't be reached but can still call outbound. I found out that the expiration is set to the default expiration 3600. If I only I could set the expiration to lower than 60 sec then my problem would be solved. My question is it possible to set in the stack application of Nokia.
Thank you very much in advance.
