hi!..
i maked this animated GIF BG ... for those that use
Extended Profiles Pro .. and like to be COOL! 8)
this gif use 128 kb... it's 16 color...
128kb i know that is some mem space... :roll:
but i have about 1.5 meg free 😊 ... so this is nice till
i need more free mem 😃
anyway i don't play "Prince of Persia" anymore 😉 (same mem space)
and now i have nice animated background 8)
Even when you are talking with someone it's cool to see the background moving behind the thumbnail of the guy you are talking to 😊
hope you all like it! 😃
cya!
HI!..
this is another Animated GIF BG...
But this ine is more like an SLIDE SHOW...
one different BG pic every 20 seconds...
so if you live the phone there.. and you will use it and push any botton... you will see one of those pics... not always the same 😊
this GIF use 90 kb... so it's not much...
hope you all like it..
cya!
Hi
How do u get that animated gif to work in extended profiles pro???
I get it as background bit it just stands there doing nothing.
I want it to move.
Hope someone can help.
THNX
Simply select the file from personalise profile on ExtendedProfilesPro...
and assign background.. and you will see a question TRY ANIMATED BACKG? ... put yes...
then you will see there... if you don't see it.. try to reboot.. and check again...
but i see it ok..
cya!
oh okee the reboot worked.
not at wonce bat when i press a button it changes the picture.
and ik moves now
thnx
P.S.
it doesn't move fast though
HI!..
ok.. yep .. i know .. doesn't move too fast..
That's because the Extended Profiles Pro App it's
converting each gif frame to .mbm and puting on the
background image file, all at real time... so the FPS are not
too good. But look nice anyway...
The BAD NEWS is a BUGG on Extended Profiles Pro.. and
or Firmware 3.16 ... (someone with 4.xx have to confirm this)
If you active any fast Animated GIF for Background..
Then, the Voice Dialing don't work :roll:
With the GIF like slide show that i created.. it's work.. but not with the
fast one...
BIG! BUGG! :-?
what relationship are between Voice Dialig and Animated BG Gif??? 😃
only GOD know that!
cya! 😃
Do these animated BG dramatically affect standby time of battery?
hi. I have 4.39 and it works fine ...
I even don�t need to boot the phone 😃
I�ve forgot... with 4.39 background gif and voice dialing work fine. 😃
I use E-profiles pro and have a Itchy and Scratchy BG which is animated, but not blisteringly quick, but not bad, anyway, I use 3.16 FW and have no problems with the voice dialing, what seems to be the problem, it not recognising the name or just not doing anything
Eck
HI!..
ok ...
when i press the speak botton... it said NOT MATCH FOUND!! inmediatly!..
but without the Animated GIF as background.. it's all back to normal.. :-?
don't know what it is.... :roll:
will check again later..
cya!
thanks for your comments 😃
HI!..
ok.. the Voice Dialling don't work while i see the animated BG... :cry:
BUT!... i found that if i go to menu or any app to leave the main BG screen back and then press the speak botton, voice dialling work fine...
So.. i can use it in that way by now...
cya! 😃
HI!...
ok .. i�ll make it more...
i was thinking to make more slideshows..
may be one for each ussual theme..
like.. one slidewhow just with babes 😊
another with cars only... 8)
other with manga ...
other with abstracts things...
anyway... you tell me a theme to create slide show GIF... fog BG...
may be with 10 to 12 pics each.. ( arround 130kb. )
cya!
i�m glad you all like it 😃
when i play the gifs as background on eprofile pro, the animation is slow and there are trails where the image has moved from a previous frame!!!
do you experience this or does it run as smoothly as on a computer screen?
the slideshows are okay since they have longer intervals between frames.....and they are stunning by the way. 😉 😃
hi..
yep the slideshow is a 20 seconds between.. i did it in that way..
but the animation... on my 7650 run not so fast but not leave trails behind...
what Firmware you have?.. i have 3.16...
cya!
3.16 aswell.
the animations run well as screensavers...im using the matrix code gif which is really cool.
I used to use an animated background, but it seemed that my battery life was drastically cut down from 3 days to 1. Is anoyone else here experiencing this problem with animated backgrounds?
yes i have experineced batterly loss, but its ok since i dont use te phone much for calls and is et it to sleepmode in 1 hour...maybe that helps it stay abit longer.
does it work under Nokia 3650? I don't see the option for the extended on the profile...
can someone help me out?
thanks
This need extendedProfiles program from www.psiloc.com to work.
Buy it, its cheap, and really good app. Cant live without it.
