N95 8GB and uploading music
2 replies · 2,552 views · Started 31 March 2009
Recently I have purchased N95 8GB with a bluetooth headphones. I was able to link up the headphones with the phone all works very well.
Next came time to upload some music. I am using the Nokia PC suite, it changes the music to some more compacted format but it does not want to transfer to the phone. It looks as if it is doing it but there is nothing in the phone. Any suggestions what I might be doing wrong? I can transfer files by drag and drop but in that format it takes a lot of space.
I think I figured it out. There is a glitch in the Nokia software. When I try to transfer using the better eACC format it does not work, but when I do the transfer with teh standard format no problem. All music gets transfereed.
You could use Wınamp to convert the musıc to eAAC+ too ıf you want to save space. Then copy them ın mass storage mode.
