nokia 5800 WLAN help!! VPN?
3 replies · 30,632 views · Started 01 April 2009
hey guys,
I recently got a nokia 5800 and i love it. I can access my home wifi without a problem, and I can surf the net without a problem.
However, I went to uni today and I had trouble setting up the wifi for it. I checked my uni website, and it has intructions to set the VPN to enable me to access the wifi, however i am having trouble finding the VPN settings?
here is the link from my uni.
http://www.its.qut.edu.au/oncampusaccess/mobilecomputing/wireless/generic.jsp
Thanks for your help guys 😊
The Nokia support for VPNs is extremely poor to non-existant.
There is Nokia Mobile VPN which I think is only compatible with specific VPN hardware and is extremely complicated to set up.
http://www.businesssoftware.nokia.com/mobile_vpn_downloads.php
For 3rd party solutions there is NCP Secure Entry which does IPSEC VPNs but is expensive and doesn't seem to work on my 5800
http://www.ncp-e.com/en/solutions/vpn-products/secure-entry-client.html
And SymVPN which does PPTP VPNs and is alot more reasonably priced but again does not work on 5800.
http://www.symvpn.com/Products/ProductInfo.aspx
Basically if you want VPN support buy an iPhone 😞
Sorry
-- Correction --
It appears that NCP Secure Entry should work on a 5800. When I originally tried it I was getting a grey screen when I attempted to connect but after speaking to NCP they confirm that it should work on 5800 and I can at least get past the grey screen this time even if I can't work out the correct settings to connect to my VPN server at home.
abe_1990 wrote:hey guys,
The instructions seem pretty straight forward. Have you installed Nokia VPN client? (Available in the Download! app)
I installed SymVPN_v1_0_B78 on my nokia 5800 and restart it and I did everything. but when I click on Verify (Verfing username and password) the screen go black and there appear some vertical lines in diffrent colors and I cannot do anything except turn off the phone with power button.
Can you help me how can I solve this problem?
