Hi. I want to turn off sounds if the phone is turned. I did like the user guides says and activated all checkboxes on "Menu > Settings and Phone > Sensor settings" (page 26). Snoozing alarms is on, but if someone calls the phone still rings.
Is this a bug? Does this function isn't supported properly?
suntrop wrote:Hi. I want to turn off sounds if the phone is turned. I did like the user guides says and activated all checkboxes on "Menu > Settings and Phone > Sensor settings" (page 26). Snoozing alarms is on, but if someone calls the phone still rings.Is this a bug? Does this function isn't supported properly?
Sounds are only silenced when you turn the phone over while it is making sounds (alarm, calls), it doesn't make the phone silent if it is left turned over.
Thanks for your help munkiii. I didn't know that.
Bye
suntrop
