Hi guys
I am looking on Zedge for some themes but I am looking on my phone.
Is it safe to download them from my phone and save them on to the phone or should I not risk it?
Dont want to break my phone in anyway shape or form etc.
Hi guys
Ashey, my theme puzzled friend - we meet again!😊
As I said before, don't save or install themes to the phone, always to the memory card.
You should be ok downloading using the phone, but if you're worried, install an antivirus program like Kaspersky on your phone just to be sure.
Well it saves the file to memory card and so I suppose its the same way of doing what you talked me through last night and just installing it to memory card so that if it is corrupt I can just delete it from my card and everything is good.
Ashey wrote:Well it saves the file to memory card and so I suppose its the same way of doing what you talked me through last night and just installing it to memory card so that if it is corrupt I can just delete it from my card and everything is good.
You got it - some users have bricked their phones by installing badly programmed themes on to the phone rather than the mem card - if you've seen my post about unbricking you'll want to avoid it!!
