My nokia n95 8 gb worked fine for a couple of months but recently the date will jump forward a day or two. Sometimes my alarm clock wont go off because the phone thinks its saturday. This happens with the network operator time enabled or disabled.
Does anyone else have this or know how to fix.
The time does not change just the date.
Hey, I've got the same problem.Do you have already a solution? or someone else???thks a lot. :icon14:
It seems like users on this forum - like me - don't know a solution for this problem . It could be an interference with another date-software using application ?
Guess to check with your Nokia Service Point . Like to hear your story .
😊 Regards jApi NL
snowtraveller wrote:Hey, I've got the same problem.Do you have already a solution? or someone else???thks a lot. :icon14:
I have had the same problem and Nokia said to update Quick Office on the phone. I've done that and hopefully it will solve the problem. I've been missing appointments and weekday alarms up to now amazing how you rely on your mobile to run your life
