Buttons not working
3 replies · 3,147 views · Started 13 April 2009
Hi all,
I noticed yesterday that the some of the buttons are not working on my 5800. For example, when I am on the bluetooth menu I cannot open the different 'tabs' to look at connection settings for adding new devices etc, or to block devices.
I also get the same thing in messaging. If I am in my SMS inbox I can't access the different 'tabs' to access my other inboxes.
I have an RM-356 with f/w v20.0.012 (hacked my country code to get this as on Orange in the UK)
Anyone got any ideas??
awginger wrote:Hi all,
my first suggestion would be to reflash the firmware and see if that solves the problem...
This can happen if you use a theme that is not 100% compatible. If you are using a different theme to the one that came with the phone, I would suggest that you change to the original theme!
robmeik wrote:This can happen if you use a theme that is not 100% compatible. If you are using a different theme to the one that came with the phone, I would suggest that you change to the original theme!
Turns out this was the problem!
Thanks guys!!
