Does anyone know how to get the alarm to use the vibrate option rather than any of the music files or defaults. with the phone set to silent no alrms can be detected without looking at the screen.
Any other phone I have used vibrates on Alarm when it is set to silent
Any help appreciated
quite straight fwd, you just have to select the "On if Silent" option which can be found on the phone preferances under sounds and alerts for the vibrting alert. Doing that will make the phone alarm vibre when in silent, thanks
That doesn't work for alarms.
The answer is no, you can't, nor can you make alarms do increasing ring.
I'm praying for a firmware update to fix this.
