Key Lock
10 replies · 3,898 views · Started 28 February 2003
left menu button quickly followed by the * key.
Same to turn it off again
Or a quick press of the power button, up, ok. The the first way is quicker..
Will
i can't find it mentioned in the manual (weird..) and neither could my friend (he has Chinese model)..
but good thing Nokia has kept the shortcut the same for a while otherwise i'd never have found it.
I only found it cause I noticed the slight delay when pressing the left menu button before the application actually starts, whereas the right key is instant.
So I assumed it was doing something, ah ha - the key lock I thought to myslef and press all the combinations of obvious keys and found it!
I've moved the camera function over the the right menu key now as the delay before the camera application started got to agaravating. 😉
Anyone know of an app. that will auto lock the keypad after a specified amount of time (10secs) like on my 5210?
Thanks.
[quote="pji"]Anyone know of an app. that will auto lock the keypad after a specified amount of time (10secs) like on my 5210?
Thanks.[/quote]
you can do the following steps to set delay to your auto lock:
Menu => Tools => Settings => Security Settings =>Auto Lock Period => options => Change enter lock code => highlight user defined => OK => you will see that the phone will prompt you Lock After => then set delay
hope this helps. 8)
But does that not lock the phone and requires a pin code entry - rather than just locking the keypad?
I have not got my phone on me at he moment so I can't try it for myself..
Will
What I want to do is disable that *nasty* 2sec delay on the left shortcut button. Then if the keylock could be assigned to for example Pen+* that would be good. But is it possible to get that 2sec delay off?
OK, I have tried SeleQ, I see the option but it does nothing.
The thing that amor7 mentioned locks the phone and you have to enter a PIN to unlock it. Also, the min. time is 1 min. On my 5210, I had it set to 10 seconds.
Any other ideas? Maybe someone could write a little app?
Paul
