Mobbler updated to 0.4.4 - sleep timer, Last.fm data
8 replies · 3,376 views · Started 16 April 2009
Mobbler, a last.fm client for S60, has been updated to version 0.4.4. The new version supports the new Last.fm Web Services, which is an official API / integration route, and should improve stability. Other new features include improved album art support, the ability to disable scrobbling, a sleep timer (perfect for using music to send you to sleep), and the ability to view you Last.fm data.
Anyone else getting "403 Invalid Request" after the album art is pulled down but before the stream starts ? Could be my operator mind you (3 IRL)
N82 btw.
On my 5800, something funky happens with the main menu. Specifically, a few seconds after opening it, it becomes almost completely invisible except for the highlighted entry.
OTOH, I love the new icons.
Now If only I could find the app in my Applications folder - installation went well, but where is the app file?
It should be in the applications folder. It might be worth trying to re-install it if you can't find it?
joeyfallon - if I recalll there were some problems with Mobbler and 3, but this is not something I have personal experience with.
it's really great, but if I add a track to playlist (and I don't have any playlists defined), the app just exits and I have to restart it
capitaine -- please report that here: code.google.com/p/mobbler/issues/entry
joeyfallon -- yeah, there's a problem with 3UK. Gerrymoth is fighting the cause to get them to fix it.
Rafe -- This website has just nicked your whole blog post: telephone-issues.com/?p=64304
