Has anyone else noticed that after upgrading to f/w v20.0.012 that your 5800 will not 'remember' the voicemail box number?
It used to be saved as speed dial 1 but now I can add it manually but then as soon as I close the menu and go back in it has lost the setting.
So everytime I get a voicemail I get the box pop up, I press listen and rather than just connecting I have to type the number in.
Had this on your 5800?? Have you fixed it??
