Hi
I have the following problem:
I work on MS Windows XP and MS outlook 2003 professional. I use Nokia Ovi suite 1.1.152.
I have Nokia 5800.
When I first installed the Ovi software I was able to synchronise my outlook calendar with no problems.
However, my subsequent updates of the calendar failed. There is no error message. The mobile seems to connect to the PC, and after I press synchro button the message afterwards states that the calendar was synchronised. However no additional entries in the calendar (both in the mobile and the outlook one) are there.
Could someone advice how to solve it?
Thanks in advance
Kudos! Thanks!
