Flash Lite
4 replies · 6,588 views · Started 18 April 2009
to wake up his thread, for those waiting for 'full flash'..... 😛
planetmike wrote:Should this Adobe web site function fully on the Nokia 5800?
http://www.adobe.com/mobile/gallery/
the quick answer is (AFAIK) most websites look for a much more advanced flash plugin... it wont find it, and so ask you to goto adobe - to find they have not got one for symbian yet!!!
(the only thing 'flash lite' seems to do is enable you to play a flv that you have downloaded!!! )
The other problem is finding a website that does not also use JavaScript at the same time as a flash plugin, to make it 'fancier'... 🙄
and then there is the problem of finding a website that is not warped too badly, by the very simple nokia browser, and that website trying to make it work on a mobile!!!... try this one...
(unlike most that use complex 'embedding' , this just uses a direct link to youtube... )
http://failblog.org/2010/08/19/epic-fail-video-street-performer-win/
