I have in the past used my N95 classic to access the Internet on my home wireless network.
Since the last time I upgraded the firmware to V30.0.015, I have been unable to do this.
The wep key is correct.
I cannot find where to check that my ip address and gateway address are still there. Memory fails me again! :frown:
Can someone tell me where I can find where my ip address and gateway address is?
In my network I assign an ip rather than have one auto generated.
dog-man
dog-man wrote:I have in the past used my N95 classic to access the Internet on my home wireless network.Since the last time I upgraded the firmware to V30.0.015, I have been unable to do this.
Did you by any chance RESTORE a backup after the firmware upgrade? Doing his corrupts the handset functions in some cases - and can be fixed by formatting the internal memory with *#7370#
Yes I did!
If I do as you suggest, I assume I lose everything in my phone memory and will have to enter everything manually?
dog-man
Hello..
If you want to use WIFI then you can use it from mobile and laptops..
I have HTC mobile in this i get the best the connectivity with wifi sometimes i used wifi in laptops also. Somewhere the password protected in wifi at that time i use the mobile in that i can use the wifi and when the password is want in wifi i normally use the 12345678 and after that i surf the that..
dog-man
Dear Friend,
It is unclear to me as to why you are not able to find these settings.
If you already created a WLAN access point then following is the path you can access it.
In "Settings" proceed to"Connections" then to "Access points" and then click on the WLAN connection name which you previously created. Having opened your WiFi access point, press "Options" and then "Advanced settings". Then press IPv4 settings. There you will find phone IP address, subnet mask, default gateway and DNS sever addresses.
I hope this solves your problem.
cheers
Thank You. That is exactly what I needed to know.
It has been so long since I last had to enter the details, I had forgotten how to do it. :icon14:
