How to transfer contacts and other stuff from 9210 to p800!!
Please reply if you know to do it!!!
Regards
Heemanshu
Regards
Heemanshu
Via the IR port on the side of both phones 😊
Every single contact induvidually, he?!
Likely, of couse you could just copy contacts to sim and put the sim in the P800 and copy from sim to P800 😉
do a search for my post on psion or revo or Psion Revo in this (P800) forum it will be the same method I would have thought
There is a difference:
The P800 (v7/UIQ) as well as the v5/Eikon machines (including Psion 5mx, Revo, netBook etc) allows you to export all contacts at the same time. I am using a Psion netBook together with a P800 and I can move all contacts between them in one go without any additional software.
This does not work on the Nokia 9210.
cheers
Martin
