http://e71unleashed.wordpress.com/2009/04/21/top-apps-for-nokia-e71-by-mobile-flipper/
Top 6 Apps for Nokia e71
Is there any applcation for the E71 like yahoo Go! but using google?
Not exactly. Google do have its applications but all stand alone application.
Will try to post an entry with E71 focused on google. Keep watching my blog.
nokiae71blog.com
thanks :tongue:
sachinmalhotra wrote:http://e71unleashed.wordpress.com/2009/04/21/top-apps-for-nokia-e71-by-mobile-flipper/
I have to say, the Gmail application is a bit dissapointing. It doesn't allow you to save attachments and for example if you receive a PPS presentation, it doesn't show it to you.
At first I was quite happy with it, but now i'm a bit dissapointed.
Anyone know what mail app i can use, which is better?
Thnx 😊
😊 Probably you are looking for this answer : since I regulary use MiniOpera http://mini.opera.com/ browsing the Web , I made a bookmark in MiniOpera for the full Gmail : http://mail.google.com/mail/ . This allowes download of attachments . However I don't have experience with PPS . But this should work as well .
😊 Regards jApi NL
jApi NL wrote:😊 Probably you are looking for this answer : since I regulary use MiniOpera http://mini.opera.com/ browsing the Web , I made a bookmark in MiniOpera for the full Gmail : http://mail.google.com/mail/ . This allowes download of attachments . However I don't have experience with PPS . But this should work as well .
😊 Regards jApi NL
Thnx 😊
I was hoping it would be different but no luck.
Anyway, thank you for your help 😊
