Has anyone ordered the Brando Workshop Protector Plus screen protector? If so, what are your experiences and where did you buy it from ?
Im living in scandinavia and would like to order it from somewhere else than Hong Kong!
Screenprotector ordering
i purchased it im in the uk and it came after a week but did eventually come and they do the job 😃
[quote="helly"]Has anyone ordered the Brando Workshop Protector Plus screen protector? If so, what are your experiences and where did you buy it from ?
Im living in scandinavia and would like to order it from somewhere else than Hong Kong![/quote]
You can try buying it from www.p800er.com
where in the uk did you buy it ?
I'm living in Norway, and I await the small package in a week or so....
If you're in no rush, it's only 12 bucks included shipment...
did you get it from p800er.com ?
no i got it from hong kong, brandos site - i wasnt aware of p800er at the time
I suggest you get it from brando themselves. I got mine directly from them. The price is reasonable and delivery time is fast
I ordered my from brando yesterday and it shiped fast. They service is very good. No problems so far if there are no problems I will consider buying memory from them
Living in Norway, I ordered mine from Brando, Hongkong. Delivery Time to Bergen/Norway was apx. 7 days, and it arrived in a stamped envelope, as a normal air-mail letter. $12 in total.
...of course I too highly recommend it!
Well i was satisfied with their service i decided to preorder my MSDuo 128MB from them. It will be available by April, and their prices are quite reasonable 😊
sounds nice, does the protector itself work good?
no problem with "touching" the screen with it attached? 😃
No chance of it falling off the phone either? its quite expensive piece of plastic ..
[quote="helly"]sounds nice, does the protector itself work good?
No chance of it falling off the phone either? its quite expensive piece of plastic ..[/quote]
I've been using it for some time now, and have no trouble with it. Be careful when you put it on, and be sure to get rid of all the trapped air, so you don't get any bubbles.
Actually it's a lot more comfortable to write on the device after putting on the Brando-film. Today I used a friend of mines P800 when testing some MMS-settings, and he doesn't have the film. Believe me, the writing-"feel" without the film was quite different, and s*cked big-time after having used it with the film for so long...
You'll never regret it!
Oh, and just to mention it, I recently put the flip back on, after getting the HCH-32 car-holder for the HCA-20 handsfree-kit in my car. No problem using the P800 with flip and film. Some users have reported problems with other films, I'm not sure if some of them used the Brando film, but for me there's no problems. (And using the P800 frequently in the hf-kit in-car without a flip is pure hell... at least on the roads over here...)
Opheim is right helly. I too find the screen protector helpful. One more thing, Brando screen protector is washable and reusable. If it gets dirty, you can peel it off, wash it and put it back 😊
ive just ordered it from hong kong 😊
you all got me worried about putting it on now tho, hope ill manage it..
what do you use washing it off, regular soap?
I really want to get a Brando screen protector but I would like to know if anyone has ordered anything from p800er yet before I part with my money.
Does anyone have any experiences with them?
[quote="marctwok"]I really want to get a Brando screen protector but I would like to know if anyone has ordered anything from p800er yet before I part with my money.
Does anyone have any experiences with them?[/quote]
So far so good.
I baught mine from Brando, and it took only a week. Very quick!
So now it's on, and I feel it's better writing and actually using the buttons! So - this was a great tips folks! Thanks!
I got a screen protector at Circuit City in the States.. This thing was made for Samsung PDA Phones and only cost $9 USD for a 12 pack. The sales rep said I might have to trim it.. But after opening it up it was a perfect fit.. I was very pleased because I didn't have to alter anything.. I'm glad I checked it out instead of wating a few days for a shipment from HK.. Circuit City also has an online store.. There's only 2 brands and it's the one made for Samsung.. Check it out..
Those PDA screnn protector are not as good as the brando. One thing is that you can't clean it, plus it is not as clear. I have tried them but now that I got the brando I know it is much better...
Although it is not easy to fit it exactly on the screen, your hand has to be very stable 😉
I have to say, Brando screen protecors are great! Ordered last week, got them in my mail today! Wow, and they apply very easily, just make sure all the dust is gone before you apply them!
Brando, great job!!! :P
