BOUNCE extra level prob
7 replies · 7,092 views · Started 28 February 2003
anyone can help me with this? i cant install extra level, there an error message like 'BOUNCE has not been installed" install bounce and try again, literally understading the message their trying to say that i dont have BOUNCE installed on my phone, but i do have it .. anyone got the same prob before? help me, thanks�
Are you sure that the level pack is for the 7650?
As far as I was aware there was a level pack for the 9210 but not the 7650.
The 9210 level packs will not work on the 7650, sorry.
Bob 😞
i did download it at nokia website, il check on the website back to make sure i download the right one, thanks for the fast response�
im pretty sure this is level packs are for 7650 because when you finish the 11th level there will be a message for more level, go to nokia .. blahblah, i cant remember the correct message though
You are indeed correct at the end of the game it prompts you to go to Nokia and download game packs, but unfortunately they don't exist.
The only game packs are for the 9210, see this link
http://www.nokia.com/games/downloads.html
As you can see there are no 7650 games!!!
We sit and wait!
Bob :cry:
I'm suprised that no one has developed a level editor yet. It looks like the game just consists of game blocks so you could open notepad like some of the old amiga games and just write a new level like....
1=wall
2=inflator
3=invert gravity
4=diamond
if you look in the installed bounce folder in your 7650, looks to be very simple the way the levels are laid out - just a separate file for each level. If someone could unpack the 9210 level sis files, surely it might be a case of just copying them into the correct folder on the phone?
Worth a try? How do I un-sis these files? ????
