E50 fota
2 replies · 4,852 views · Started 24 April 2009
If the E50 supports FOTA and Nokia supports FOTA for the E50, then you don't need any links; you upgrade from the phone and the firmware comes from Nokia.
*#0000#, Options, Check fur Updates. If Check for Updates isn't there, it means the phone does not support FOTA.
