Nokia PC Sync problem with 9500
1 replies · 4,967 views · Started 24 April 2009
Hi all,
I have a problem, I downloaded PC Sync program and installed it on my PC. I connected my 9500 with my USB cabel to PC and everything is ok, but when I want to syncronize I get this message all the time:
Please check your Synchronisation settings and ensure your phone is in the Idle state, then restart the Synchronisation.
I tried everything, any solutions?
Thank you
Hi, I had the same problem. And my solution was to go into tools -> sync -> PC Suite -> edit sync profile -> applications and then define settings for the things I wanted, in this case Contacts and Calendar. Then, I edited - selecting Yes to say that I wasn't worried that not all settings were completed. Then, it all started working.
Hope that works for you too.
M
