Screen transitions on E75
1 replies · 4,520 views · Started 26 April 2009
I know, I know, this is hardly the most important part of the awesome E75 but, having had one for 24 hours now, I'm mystified as to where the screen transitions are.
I've never owned a FP2 device before but I'm sure I remember seeing the E75 demoed and it had screen transitions and menu animations. Mine doesn't and, having explored the depths of every menu, I can't find any way to enable them.
No doubt I'm being stupid. Can anyone point me in the right direction?
Not sure about animated icons, but theme effects can be turned on by going to Themes in the Control Panel, select General, highlight the theme and then select "options" - there is a "Theme effects" option that can be turned on or off. Hope that helps.
