e71 startup and taskman?
5 replies · 5,576 views · Started 27 April 2009
how can i see what loads up at startup and what is running on my phone.
i find that battery drops fast because i got so much install'd on it.
Need like a process monitor. want to try this before i have to reset the phone.
thanks
Not sure how to check what loads at startup, but to see what is running at any point in time, hold down the home key.
i posted an url of jbaktaskman wich is a VERY good taskman. For some reason they didnt approve this posting so search for yourself i would say
Yes , it seems like URL's are stored in separation on the server at the moment ...
Anyway Y-Tools from DrJukka is a nice app to see how much occupied the C: D: E: disks + RAM are . And has some more festures .
With Y-Browser and X-Plore you can delete Cache content .
Be sure : always install on MemoryCard , to save Device Memory .
☺ Regards jApi NL
Can you install apps i.e. conversation/nimbuzz etc on the memory card? As long as the memory card is installed would it work?
😊 Yes ! When you download OTA - e.g. Over The Air , you will see a choice between Device or Memorycard . Always choose Card in order to save DeviceMemory . A tiny amount of Applications need DeviceMemory . This is done automatically .
Taking out Card from your phone is naturally disappearing the Apps , but Replacing the Card they are back again !
😊 Regards jApi NL
