N95 8GB Questions....
1 replies · 2,310 views · Started 27 April 2009
I just upgraded from a N95 to the N95 8GB. First thing I did was upgrade the firmware to the latest release.
I have two immediate questions:
1. How do you get the bluetooth headset to auto-answer?
2. Has anyone had problems getting bluetooth headsets to be detected by the phone? I have a Plantronics 510 (Bluetooth 2.0) that worked GREAT with my N95. The N95 8GB cannot detect it and I needed to go back to my old Nokia HS-W4 headset (Bluetooth 1.1).
Has anyone had a problem getting Bluetooth 2.0 devices to detect on the N95 8GB?
Thanks.
Auto answer is as follows:-
Menu > Settings > General > Enhancement > Headset > Options > Open > Automatic answer (set to on).
As for the compatibility issue, depending on what firmware you have installed at present, you should find that a firmware upgrade will solve the problem. Latest firmware version for N95-2, generic, is V31.0.015.
You can check here for your latest firmware:-
http://europe.nokia.com/A4577224#
Good luck!
