YouTube's S60 client returns to normal speed
10 replies · 5,258 views · Started 30 April 2009
Google's YouTube team thankfully seem to work at a fair old pace. In this case following up a new client (S60) with several updates to fix bugs. The latest is v2.0.11 and fixes a major bug where videos played at high speed on some devices. You can get the (excellent and free) YouTube client for any S60 3rd Edition phone by going to m.google.com in Web.
m.google.com then clicking on 'youtube' seems to just take you to the mobile web interface. Where do I get the client?
Ah - if you don't see a Download link, then it means that your device isn't officially compatible. What are you using?
slitchfield wrote:Ah - if you don't see a Download link, then it means that your device isn't officially compatible. What are you using?
I'm using N82 and same problem here. Though I don't even know what are supported devices. But I know, that YouTube application (v.2.0.4) runs very smoothly on my Nokia.
BR/
Petri
Interesting. When I click on YouTube on m.google.com I get a huge 'Install now' affair/link. Maybe your N82 has had its user agent modified? Can't think why you wouldn't see the app otherwise....
Ok, now I got that working. I had to change Google's language to English (it was Finnish) and now there was that YouTube link and everything went just smoothly.
First I tried to go to m.youtube.com and there was also that link "Download the YouTube application", but when I click it, there came page in Finnish which said that my device is not supported. Weird. =)
BR/
Petri
I get this on my N96 too. No sign of the application.
On N95 and N95-8Gb it prompts to install version 1.4.7
�maybe is country based? I'm in Colombia.
