Widget maps of London Tube, Paris Metro, New York subway and Tokyo subway
9 replies · 4,583 views · Started 30 April 2009
Released as free widgets for the Nokia 5800 and N97, PixelsBeatPaper has released interactive maps of the titled underground systems. Nothing fancy, just clear scrollable maps. If you dig a bit further into their site, you'll see utilities for bill splitting, body-mass-index calculating and a countdown timer, all again only for S60 5th Edition.
Mostly very nice. Unfortunately the TFL map of the London Underground doesn't work properly - you can't scroll around the map at all from its default position, giving only a small % of the total network.
On the 5800? I tried it on the N82 and noticed this, but assumed that was because I was using the wrong device 8-)
TFL works on N97 (though it vibrates when you move the map about which isn't very nice and it doesn't fill the entire screen in landscape)
Split the bill works too, handy!
As the Omnia HD works on same OS will these widgets work on that device?
the countdown timer is rotten, even free it's overpriced,
are there any free countdown timer apps for the 5800 ?
I dont have any problems using the TFL London map, although it's best kept at portrait. I don't see what benefit it has though. I already have the map downloaded from the TFL website and stored on my 5800 as an image. And this is pretty much the same thing.
The map is installing fine on the E90 . But using it , the phone gets allmost freezing . It's possible to zoom in , but then you can not move around in the map : doesn't react to D pad .
😊 Regards jApi NL
jApi NL wrote:The map is installing fine on the E90 . But using it , the phone gets allmost freezing . It's possible to zoom in , but then you can not move around in the map : doesn't react to D pad .
😊 Regards jApi NL
Err.... the widgets are explicitly for touch and S60 5th Edition!
Steve
