There is a problem with my voice recorder. When I switch the recording mode from Normal to Compressed one, it couldn't be switched to the compressed one...What should I do? And is this one of bugs at the firmware v3.18???
Voice Recorder problem
I had the same problem with 2 versions 3.62 and 4.13... I've spoke with Nokia support and they told me that is a bug and they haven't solved it yet....
What??Mine is v3.18...I have been told that the only way to record the normal or compressed mode is to save a file as the normal or compressed mode, and when you wanna record at normal mode, you can open that normal recorded file and go on recording; same as if recording at the compressed mode. Otherwise, you have to use the DictaPhone to record.
I cant get compressed mode to work, but how can i tell which version I have anyway, its a new phone (1 week) but i doubt its the latest software.
Steve
You press *#0000# on the front side of the phone and the software version appeares in the screen.
Teun
Cheers
3.62 - looks like i should be looking to upgrade it at some point - tho i dont think i can live without it now ive got it
Decisions decisions!
Hello. I say that the problem that has east man with the recorder of nokia 9210 I have had it I, counting, as story, with the version of Firmware 4.13.
I was able to solve it of the following way
Having before made a backup of all the archives (when still the recorder worked), one is to recover these archives of the backup in nokia 9210.
I do not know why the recorder in trustworthy conditions does not work. Personally (I do not know if to somebody it will happen this same one more to him), I often feel fear when I use nokia 9210, because, really that I believe that it is going to be the last time that does it.
I already know that everything is solved taking the telephone to a technical service of nokia, while this has guarantee at least, but, is not to be a telephone a month yes, and no.
In aim. It tries "to return to normality" to your nokia 9210 by means of the archives of your backup� That you do not have made a copy? Then� I do not know what to think, then� I do not know if he would be worth archivo/vos el/los that I am using, because if outside thus you do not have more to communicate than you need them (not with nokia 9210 communicator, but in this forum) and I will deal with consegu�rtelos, with the purpose of ahorrarte to go to the technical service.
Nothing else. Until soon.
Excuse me. I don't understand what you are talking about! Can you speak in plain English? Or anyone can give a crystal explanation here, thanx^^
In filemanager, go to System\apps\Voicerecorder directory (in main memory not mmc).
Delete the Voicerecorder.ini file.
This should allow recording with compressed again. Occationally it switches back to normal, and you need to do the above again.
Hope I understood the question correctly.
Zuber
The only way to change this you will find here http//www.aikon.ch/cgi-bin/faq/faq.cgi?subject=1014769080
take this to files....open norm.wav and the recorder change to normal, take the kompri.wav for compressed!!!
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2002-04-14 1206, Zuber wrote
In filemanager, go to SystemappsVoicerecorder directory (in main memory not mmc).
Zuber
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
OK..I understand. Thanx.
