hi all,
i've a problem when scrolling on a view which displays HTML file. my problem started when i tried to supported "EButton1Down" Event by implemmenting "HandlePointerEventL" function. before adding thi function the scroll bar appears correctly and it works too in all HTML views. but when i added this function "ButtonDown" action worked correctly but it affected in scroll bar in all views that reqiure scrolling.
i can't get why this behavior?
for more details. my "HandlePointerEventL" function is as follows:
void CTawafCounterContainer::HandlePointerEventL(const TPointerEvent& aPointerEvent)
TPoint position;
position = aPointerEvent.iPosition;
if(aPointerEvent.iType == TPointerEvent::EButton1Down )
if(aPointerEvent.iType == TPointerEvent::EDrag)
iBrCtlInterface->HandlePointerEventL(aPointerEvent);
if(aPointerEvent.iType == TPointerEvent::EButton1Down)
if(iTopLabelRect.Contains(position))
StartLKPTimer();
else
iBrCtlInterface->DrawDeferred();
i added this function bcoz in the same view i need to handle user clicks on a certain position were when he clicks in (x,y) a counter will increase else i want to check if EButtonDown && EDrag then view scrollBar.
how to do that ?
thnx.
