Shortcuts gone?
4 replies · 4,510 views · Started 03 May 2009
Hello all,
I was disconnecting from my mail server when phone started slowing down and main screen froze (none of the buttons working). I restarted it and still nothing (hard buttons on the bottom work, but nothing on touch. I pulled the battery and still nothing. Short cut bar was gone, but when I press in their area you can see the square, but nothing happens.
Long story short the only key that works is the media key. When I change to contacts bar everything works, but when I go back to shortcuts bar it's the same thing (nothing working). I have re-installed the software through nsu, but still nothing.
Any ideas or thoughts are appreciated,
Jerry
sanscritt wrote:Hello all,
Jerry
Hi Jerry,
I have the same problems : before only bar contacts, then bar shortcuts and home screen default.
The first problem is appeared with the 20.0.012, the second with the 21.0.025.
No solution here, neither on nokia forum (http://discussions.europe.nokia.com/discussions/board?board.id=smartphones) 😞((
So I've installed Handy shell as recommended by another guy.
Regards,
ThieRy
I had the same problem and used the same solution i.e. installed shell, but having done a hard reset as detailed in the thread Freeing up Memory all is now back to normal and working fine.
bobthebuilder wrote:I had the same problem and used the same solution i.e. installed shell, but having done a hard reset as detailed in the thread Freeing up Memory all is now back to normal and working fine.
I suppose that you have made a backup before.
So after a hard reset and restored the backup, do you have found your N5800 as before?
Thanks.
ThieRy
tnaquin wrote:I suppose that you have made a backup before.
Thanks.
ThieRy
Yes did a full backup, hard reset and then full restore the only programs I had to manually reinstall were :
Google maps
Mobi officesuite
F-Secure
Both the last two kept their fully registered status after re installing
The only serious issue I had was that my future calander appointments were lost.
