T9 prediction preferences
2 replies · 1,871 views · Started 05 May 2009
Is there any way to change the preferences of the T9 predictions? It can be pretty inconvenient sometimes, and i was just wondering...
kaiz0r wrote:Is there any way to change the preferences of the T9 predictions? It can be pretty inconvenient sometimes, and i was just wondering...
When using the alphanumeric keyboard pressing the "#" button (bottom right) will toggle caps on and off, and T9 input. So you can turn it off that way. You can also make adjustments under Settings>Phone>Language>Predictive text.
Hope that helps!
Oh i found out that the only way is just to delete the .dat file inside C:\predic. I was just wondering if there was a way to edit the file instead. Its too bad. hahaha.
thanks anyway! 😊
