9210 software v 3.18 files needed
3 replies · 3,579 views · Started 01 March 2003
I have a 9210 with software version 3.18 dated 05-06-01 RAE - 3
I have tried loading All_Nokia_9210_data.SIS which is for 3.54 or 3.62 but PC Suite processes the sis file then errors with " File corrupted or not found" message
THe following files do not work - hence me wanting to get a copy of the correct 3.18 sis files
Data Mover - not enough memory
Install/Remove - INvalid
My memory settings are
Device Memory In use 1662 Free 2376 kb Documents 8200 kb, Sheets Faxes & sounds 0kb, mails 1845bshort messages 202bcalendar, contacts, 0b, images 168b, Installed Apps 302kb, Other file types 1182
I have full net access, email and set up MS Outlook syncronisation.
I recently installed Citymaps, but now I cant run or uninstall it! I think it has something to do with Outlook data hogging all the space
Does anyone have the 3.18 software sis files please
Do I need to format my 9210 and the card
How can I uninstall Citymaps etc
I have Switcher which seems to have sorted out a few probs
Any help gratefully received
Kevin
Memory Card In use 8548 free 7084kb Docs 98k sheets 717k, sounds 47k calendar data 2821kb contacts 76k, images 144k, installed apps 1886k, other files 6293
Thanks Ross - I have fully resolved this problem now.
Frst I backed up the memory card and the C dive via PC SUite to my PC - then I formatted the 9210s C drive and the MMC card after downloading the 2 system/mmc sis files from Nokia website.
Then I intalled the sis files via PC Suite and hey presto - a fully working clean quick 9210 - Nokia are sugesting that the later system software is not compatible with my early machine - not the case - everything works perfectly.
Reset my internet/email settings and all working great !
Kevin
