Hi P800 owners,
I have had my p800 for about 2 weeks now and i love the phone but have one major problem. I am running Outlook 11 beta 2 and Win XP SP1 with parts of SP2 and am running into a problem, I can sync everything like my tasks, notes, contacts, but not my calender?? I tried using my hp 1910 and it works just fine. Is anyone else running into this problem? I am thinking about going back to my Office XP and see if that helps but office 11 is so much better. If anyone is running the same combonation as me or same but with office xp, I would appreciate and feedback on your findings.
Thanks Shane
Problems synchronizing with outlook xp
I am also facing similar synchronisation problem. Have you got any Solution till now?
Also, is there any way of enabling delivery receipt of SMS? Enabling the option under MMS-Advanced doesn't seem to work for SMS
There seems to be no way yet for deliverey conformation on sms. As for the synchronizing it is still a problem and have no solution yet I am going to revert to office xp and see if that does the trick, I hope that it is not a prolem with office 11. If it is I will just have to write it up and send it in.
I've had no sync problems with Outlook XP after an initial snafu.. XP with latest service pack and Outlook XP poses some weird problems.. However, after the initial snafu when Calendar ceased to respond I simply restarted the Sync process and all was well.. Haven't had another problem with it since.
