Programs shutting down
2 replies · 2,490 views · Started 06 October 2001
Intermittently I find that my Calendar and Contacts applications shut down without any error. This is very annoying as without the Calendar app no alarms sound. Anyone else have this problem? Any solution to this? Firmware version is 3.54.
Appreciate any help.
Thanks,
Yogesh.
<font size=-1>[ This Message was edited by Yogesh on 2001-10-06 1908 ]</font><font size=-1>[ This Message was edited by Yogesh on 2001-10-06 1910 ]</font>
I had that problem with 9210 ... I had software updated recently and now it's working... better... although, from time to time, SMS or fax functions do not operate and I have to disconnect battery for about 15 seconds....
Well,
The shutdown of my 9210 happens when I'm trying to format my MMC card. And the strangest thing is that I can not predict when the Communicator stops functioning... (during the format is happended at 2%, 4%, 10%, 25%... result is a Corrupted / Unformatted MMC card, very, very annoying!!)
Hopefully V 03.77 will be released soon...
Goswin (still a proud 9210-user User posted image )
