I have a problem with deleting apps that came with the phone that att has installed on it. Can i some how hack into the phone and delete them, Or reinstall the software? what can i do to remove them. They are driving me nuts
Nokia E71x, Deleting Pre-installed Att Apps
What apps do you refer to, specifically?
How, exactly, do they drive you nuts? Do they somehow start automatically and interfere with something else?
Are they visible in the App.mgr? If so, tried uninstalling them from there?
Otherwise, can't you just ignore them? Move them in the phone menu to a submenu you never open, for example?
They are AT&T bloatware and you can't uninstall them yet, hopefully someone will figure it out. I just rearranged my folders to help cut the menu down. All the apps in the menu screen can be moved to a folder, except for ATT GPS and ATT Music.
